Affinity Photo Beta 1.6.0.76
Avis aux Beta-Testeurs (dont je ne fais pas vraiment partie...) :
Au même titre qu'Alain signalait hier la sortie de la nouvelle version Beta d'AD, Serif met à notre disposition la dernière version Beta d'Affinity Photo 1.6.0.76 :
https://forum.affinity.serif.com/index.p...eta-16076/
Correctifs issus du forum officiel :
Fixed document draw for display scales other than 100% and 200%
Allow Colour Picker on ALT key in the Background Erase Brush
Changed Colour Picker "Presets" to "Radius" text
Fixed crash when attempting to open documents which we don’t understand
Changed HDR merge to get linear data from RAW files so it doesn’t need to estimate the tone curve
Fixed HDR merge of portrait RAW images
Reduced memory usage during selection refinement
Fixed clone / heal origin cursor issues
Fixed crash when dragging text onto document during develop
Fixed stabiliser context bar options not updating when switching modes (thanks Aammppaa)
Fixed transforming objects leaving part of the original object position visible
Fixed reading of non-fractional EXIF resolution property
Fixed crash when attempting to re-open a document which had failed to autosave
Added Russian translations
Fixed bad selection refinement border
Fixed failure to load EXIF information for file paths which contain non-ANSI characters
Fixed failure to load multiple image files at the same time
Fixed auto slices not moving when the parent objects move
Added support for tablets being plugged/unplugged while the app is running
Fixed Print dialog has truncated text and list control
Fixed CMYK values being able to exceed 100%
Fixed Character panel font type dropdown is not remembered when docked
Fixed files saved with selections are not reflected correctly when reopened
Improved line breaks for Chinese text
Fixed memory leaks during Auto-Levels / Auto-White Balance
Fixed crash in Panorama after using transform tool
Fixed crash on some documents using UnsharpMask and smart selection
Fixed PDF import of clipped groups containing a single line of text
Fixed PDF import of vector clips
Fixed preview brush nozzles not representing the current tablet rotation/tilt/angle
La traduction très approximative de Google :
Document de document fixe pour les balances d'affichage autres que 100% et 200%
Autoriser le sélecteur de couleur sur la touche ALT dans la brosse Effacer l'arrière-plan
Choix de couleurs modifiées "Préréglages" au texte "Radius"
Correction de collision lors de la tentative d'ouverture de documents que nous ne comprenons pas
Modification de la fusion HDR pour obtenir des données linéaires à partir de fichiers RAW afin qu'il ne soit pas nécessaire d'estimer la courbe de tonalité
Correction de la fusion HDR des images portrait RAW
Réduction de l'utilisation de la mémoire lors du raffinement de la sélection
Problèmes corrigés du curseur d'origine clone / cicatrisation
Correction de collision lors du glissement du texte sur le document pendant le développement
Les options de la barre de contexte du stabilisateur fixe ne sont pas mises à jour lors des modes de commutation (merci Aammppaa)
Objets de transformation fixés, laissant une partie de la position de l'objet d'origine visible
Correction de la lecture de la propriété de résolution EXIF non fractionnelle
Correction du crash lors de la tentative de réouverture d'un document qui n'a pas réussi à sauvegarder automatiquement
Ajout de traductions russes
Correction d'un mauvais affinement de sélection
Correction de l'échec de chargement des informations EXIF pour les chemins de fichiers qui contiennent des caractères non ANSI
Correction de l'échec de chargement de plusieurs fichiers image en même temps
Les tranches automatiques fixes ne se déplacent pas lorsque les objets parents se déplacent
Ajout d'un support pour les tablettes enfichées / débranchées pendant l'exécution de l'application
La boîte de dialogue d'impression corrigée a un texte tronqué et un contrôle de liste
Les valeurs CMJN fixes pouvant dépasser 100%
Le menu déroulant du type de police du tableau de caractères corrigé n'est pas rappelé lorsqu'il est ancré
Les fichiers corrigés enregistrés avec les sélections ne sont pas réfléchis correctement lors de la réouverture
Corrections de ligne améliorées pour le texte chinois
Correction de fuites de mémoire pendant les niveaux automatiques / Balance automatique des blancs
Correction d'un crash dans Panorama après utilisation d'un outil de transformation
Correction d'un crash sur certains documents à l'aide de UnsharpMask et sélection intelligente
Correction de l'importation PDF de groupes coupés contenant une seule ligne de texte
Correction de l'importation PDF de clips vectoriels
Les buses de brouillard prévisualisées fixes ne représentent pas la rotation / inclinaison / angle actuel de la tablette
Merci pour l'info, bon week-end.
